It is currently Wed Apr 30, 2025 10:58 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Wed Aug 15, 2018 5:27 pm
Hi.
My H2 motor rebuild is just sitting, cause I can't find the proper Clutch Release Mechanism.
I need the one for an H2-C. It has the "outer" half with the ball bearings, and the "inner" half with the "C" clip at the bottom of the gear.
It's a beautiful rebuild going on, so the part needs to be in excellent condition please.
Also, can't find the Neutral Switch, part #13151-012.
Any help would be GREATLY appreciated.
Thanks,
Erle
PostPosted: Wed Aug 15, 2018 8:37 pm
Here's a brand new neutral switch: https://www.ebay.com/itm/NOS-OEM-13151- ... SwImRYCRl~
PostPosted: Wed Aug 15, 2018 10:18 pm
Ralf Gillie makes a far superior replacement. I can get you his information if you so desire.
PostPosted: Thu Aug 16, 2018 4:29 pm
Thanks Mike, but the 13151-014 lists for the 250-400's. The H2 needs 13151-012.
Apparently, they're not the same. They sure do LOOK the same???
PostPosted: Thu Aug 16, 2018 4:35 pm
Thanks much Ja-Moo. If it's different from THIS---- https://www.ebay.com/itm/H2-H1-KH-Brass ... SwGOxW~qTA ----then I would definitely like a link, or more info.
Thanks again.
PostPosted: Thu Aug 16, 2018 7:04 pm
I have an H2 and a KH400. I just took a look at them and they look the same, though I can't say for certain.
Here's a used H2 switch: https://www.ebay.com/itm/KAWASAKI-H2-75 ... SwUf5bZLkv
PostPosted: Thu Aug 16, 2018 8:29 pm
https://www.ebay.com/itm/Kawasaki-H2-H1 ... SwiSJbdgqD
PostPosted: Thu Aug 16, 2018 10:53 pm
Thanks again.
It is different, I will get you a E mail.
PostPosted: Thu Aug 16, 2018 10:59 pm
Here it is. His is the best of all the aftermarket actuators. :thumbup:
http://www.gille-restauration.de
PostPosted: Fri Aug 17, 2018 9:11 pm
Ja-Moo
Ralf's has a spline similar to the Sytec, probably similar travel. Z1 sells one where the spline is similar to the ball bearing Kawasaki release. More travel, but more pull tension.
MachVmotors has 2 ball bearing units listed on fleebay, one new one used. All better than the original nylon Kaw units.
Don
Don
