Quote:
First gen have the transfer cut out way above where they need to be, and are prone to cracking. My personal last choice.
Exactly.........I am wanting to build a more hopped up top end.........like around around 100 HP........pretty well know what I want to do.........the late model cylinders cutaways can be raised a bit to match the Wossners..........and leave plenty of material (liner) between the inlet port and the cutaways........with the First Gen, there is very little metal there........they can and do crack........hate to spend a few grand and have a cylinder crack.........some racers say don't go any more than the 2nd bore oversize........maybe they use the same forging for a piston........they get a bit heavier when running a 790cc 6th size out..........than a stock size 71.5mm
Agreed, if it was a stock H2........the First Gen do make the most power (74 I beleive is what they claimed)............and the ports are oriented differently (more foward)..........those would be the ones to get
Moo did my current B\C cylinders..........stage 1..........I like them a lot and gonna leave them alone the way they are........pristine.....he raised the cutaways just enough to match the Wossners at BDC..........any more cutaway is kind of useless anyways..........as it's covered up by the piston skirt when needed the most..........at least with Wossners it is, I think Wisecos too, not sure about early H2 pistons
THX Phil
