It is currently Sat May 03, 2025 12:11 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Tomcat h2 pipes
PostPosted: Mon Sep 26, 2016 6:25 am
Thank You Jorgen, good stuff!
As you know my set-up, here is what I have found out recently much to my surprise….
My tach goes WAY off as the rpm's rise, so I was never letting this bike rev much past 7500rpm in the past.
Now that I have used Gear Commander to figure out Rpm = to MPH and watching my MPH it appears the power starts at about 5500rpm and it just begins to tapper off at what I believe is about 9500rpm. (somewhere at 9000 and above)
Still hard to be totally accurate and I don't like to hit that high rpm often!
Maybe this makes sense with the info you just posted.
PostPosted: Tue Sep 27, 2016 11:56 am
Hi Joe.
Yes, that's probably what happens since you also have specII
When you have Your bike for a dyno run, you will probably see the curve starts going Down at about 88-9000 rpm, then tends to rise again.
I can recommend KOSO tachs. Cheap, looks good and easy installation and spot on (digital)
When you have a ported triple, I think it is wise having a tacko you can trust.
I will look up my old fbg dynosheet, and you can have a look at the specII tuning thread for dyno sheets as well (using VM34's, NOT 38's as With them fbg's I dynoed......major difference)
PostPosted: Tue Sep 27, 2016 8:03 pm
:thumbup:
Thx
Users browsing this forum: Google [Bot]
