It is currently Fri May 02, 2025 3:34 am
PostPosted: Tue Nov 14, 2017 11:56 pm
pmcburney wrote:
Thanks for the replies and advice!
I'll likely go with the Patrick Bras kit, although the 10mm 'bolts' in that kit have a nut at each end...
Are the OEM bolts, bolts (with a head as such) or are they essentially a rod with a threaded section on each end like the Patrick Bras kit?
His kit is more like a early H1 design. Mosty all wrong for a H2, except for 2 short bolts. The 8mm bolts are the only pieces you can't find new or restored easily on eBay.
PostPosted: Wed Nov 15, 2017 12:39 am
Ah, ok.
I can fairly easily source the 8mm bolts here, as that's not an altogether unusual size - the long 10mm ones don't exist anywhere but in Kawasaki's parts catalogue or an engineering shop...
All I really need is one of the 10mm x 274mm bolts, the two 8mm x 125mm bolts and some washers and nuts to suit both bolt sizes.
So... if anyone has one of the 10mm jobbies?
'66 T20
'72 H2
'74 GT750L
'76 RE5A
'80 GS1000ST
'82 GSX1100SZ
'82 GSX1100SXZ
'86 RG500G
'09 DR650SE
'10 GSX1300R
PostPosted: Wed Nov 15, 2017 6:49 am
...Let me check what I have, I went through this a few (Well, like 20 years ago!), and have some agro 10mm bolts left over. I picked the best ones for my eternal project, but I'm sure I have some bolts that will do the job....they will need a wire wheel, and re-zincing, but I have them! Plus, I'm in Australia......give me a day or so , and I will check. They are yours, if I can find them! :think: :thumbup:
PostPosted: Wed Nov 15, 2017 11:38 am
I have everything except for the 8mm bolts. All re-zinc coated. In USA
PostPosted: Wed Nov 15, 2017 7:08 pm
Hey, thanks Rod!
I'll take one of the 10mm x 274mm bolts off your hands!
'66 T20
'72 H2
'74 GT750L
'76 RE5A
'80 GS1000ST
'82 GSX1100SZ
'82 GSX1100SXZ
'86 RG500G
'09 DR650SE
'10 GSX1300R
PostPosted: Mon Nov 20, 2017 5:28 am
P.M. me your address, and I'll send 1 your way, it will need a re-zinc! Just 1 10X270mm bolt needed? :think:
