It is currently Tue May 13, 2025 11:32 am
PostPosted: Fri Feb 07, 2014 12:13 pm
PostPosted: Fri Feb 07, 2014 12:44 pm
Nothing - it's Perfect :thumbup:
PostPosted: Fri Feb 07, 2014 1:21 pm
Not much without a fuel tank.
PostPosted: Fri Feb 07, 2014 1:49 pm
yes don't see a fuel tank so with gasoline only on the carbs you should do a quater of mile no more, so why put brakes :D
PostPosted: Fri Feb 07, 2014 2:29 pm
Brakes on that thing are just fine, two reasons, when the throttle is shut all the way down, the compression braking will do the second function, spit the screwball riding it, straight off it, and, it won't matter much directly after all that.
Fuel tank isn't an issue, only needs a carb bowl full, or, two, to get that disaster to "terminal velocity", then....see ('compression braking') above.
Interesting fact about Dick Mann, AMA racer of long ago. In his childhood, his first bike was a 'piece it together' thing, BSA Bantam. He got most of the bike, fixed it, but, didn't have, nor could afford a fuel tank, so, the enterprising Mr. Mann did the best he could. He obtained an extra heavy duty small diameter truck tire inner tube, and mixed his fuel/oil, as the Bantam engine was a two stroke, filled the tube with the fuel/oil premix, fitted the fuel line to the valve stem, and, hung the filled inner tube around his neck. This got him the fuel tank he needed, to use that bike to deliver his news papers on his route in Richmond, California, eons ago. Need certainly is the "mother of invention" for some really creative people.
Now, IF the rider of that mess in the picture above were to use the Dick Mann fuel tank method, I would see perfectly just why the two factor theory would be the way to go, see (compression braking, and, 'spit the screwball riding it, straight off it' references) above.
PostPosted: Fri Feb 07, 2014 10:22 pm
Ric wrote:
Them's some Hot Pipes! :lol:
PostPosted: Sat Feb 08, 2014 11:48 am
Just noticed....all that power and weight, and.......NO RIM LOCKS OF ANY KIND, TOTALLY SUICIDAL.
