It is currently Sun May 18, 2025 6:17 pm
PostPosted: Sun Apr 13, 2014 10:45 pm
I have restored more than a half dozen triples now and wonder why some start first kick every time.
I am finishing another 72 H2 this month and this bike starts so well. When I took it in last month it had been
sitting for a least 4 months. Started first kick, amazing. Had to take off the cylinders to bead blast off the black
paint that someone applied and decided it needed new pistons and a first overbore. Cylinders and heads came
back from Don K. and looked great a usual. Got it back together today and it did it again, started first kick, amazing.
Most of these bikes seem to take at least 2 or 3 kicks to start after they sit for a while but not this bike.
My own 72 always takes 3 or 4 kicks to start after it sits for a while. My thinking is maybe because it has
a lab seal crank that could be a factor. I always use my same All in one CDI test box to start a bike after
a rebuild so maybe some stators just have a lot more zap to them?
PostPosted: Sun Apr 13, 2014 11:37 pm
The carbs may be leaking a little fuel into the engine when the "good" bike is parked, causing it to start easier.
PostPosted: Sun Apr 13, 2014 11:56 pm
That is a good question. I have thought of that many times before. My best guess is it's all about pressures. Engines that have the right combination of ring seal, compression, vacuum, etc seem to have quick starting capabilities. As we know, worn engines can be a bear to start. Even identical engines built the same will have different characteristics. I think a tight engine delivers a strong, sharp signal to the carb which helps with starting. But that would be useless if the ignition did not work properly. Just as tolerances can produce a lemon, they can also produce a jewel. :think:
PostPosted: Mon Apr 14, 2014 3:08 am
If you know the bike is set up well, trying killing it at night (or after a ride) not with the ignition switch, but just by pressing the choke lever, using this method my Triples always start first kick the next day or the next week 8-)
PostPosted: Mon Apr 14, 2014 11:11 am
also depends on condition of ignition. beats me. i have a buddy with a 71 bonnevile with the stock amals. 1st kick every time.
any bike i have with a zeeltronic takes at LEAST 2 kicks. my g3? 1st kick cold every day. go figure.
PostPosted: Mon Apr 14, 2014 6:02 pm
http://www.ebay.co.uk/itm/MOTO-REVUE-N-2109-H2-KAWASAKI-90-SS-DX-350-750-500-650-BMW-R-69-S-GILERA-50-1973-/301153684192
PostPosted: Mon Apr 14, 2014 7:29 pm
My Girly Bike will start on the 1st kick if ridden daily. If it sets, ignition off, fuel and enrichener on , 2 priming kicks. Then ignition on and starts on 1st kick. The S2A and H2 will take several kicks unless ridden often.
PostPosted: Mon Apr 14, 2014 7:53 pm
Like RB says, choke it on shut down.......... :D fuel in.....
PostPosted: Mon Apr 14, 2014 8:14 pm
The question was why some triples start on the first kick and some don't. I stand behind my answer that something is leaking a little gasoline when parked. Even if I'm wrong, I'm standing by it. :lol:
PostPosted: Mon Apr 14, 2014 8:27 pm
My H1 starts in 1 kick if sitting for 8 months or 8 minutes.
The carbs are 34mm on denco manifold blocks, so are at an angle. I think Jim is right that it has to do with an itty bit of fuel leaking in while parked or while shutting down. It also has rubber crank seals, which I believe help in starting as it doesn't take a "charging kick" as I believe a lab-sealed triple needs...
None of my Lab-sealed H1 or H2's ever started in one kick when cold. Always 3 or 4. Once warm, then yes.. one kick.
