It is currently Sun Jun 08, 2025 7:35 am
 Post subject: fork oil
PostPosted: Tue Jul 10, 2012 7:25 am
What is the recommended fork oil weight for my 72 H2?
 Post subject: Re: fork oil
PostPosted: Tue Jul 10, 2012 8:32 am
All the manuals are here if you want stock specs- http://www.kawtriple.com/mraxl/
I run 20 weight in mine with about 25mm extra spring preload and late type dampers.
PostPosted: Fri Jul 13, 2012 6:23 pm
20 sounds heavier than usual, but i guess its all about what works for you. I use 10wt with 15mm preload and its on the heavier side for me anyway. The fork oil height is always adjustable too, but I stick with the manuals specs
