You are looking at a tidy sum of money but you already knew that. The piston/rods/crank will run in ROUGH $, 1200-1500 figuring each piston set at 120, each rod at 110, the crank work at 550 plus some extra for labor.
Boring varies but 40 each should cover it being done correctly. Now, having that engine all apart, it would be a shame not to at the very minimum tidy up the cylinders by matching the ports or doing a mild porting job to really open your 500 up. That can run anywhere from 50-200 per cylinder depending on what they do. So figuring 100 per, you're up to 1800 total and you still need to add the gaskets and seals for the tranny. Speaking of which, to send it off to Mark in Fla will run around 600 IF you don't need a bunch of gears and forks so now your up and over 2500.
Just some quick math to start the guys answering....I'm sure there will be varied opinions but in very rough numbers.....it's a lot of money.
