It is currently Thu May 01, 2025 10:13 pm
 Post subject: Stuck Carburetor slides.
PostPosted: Sat May 28, 2022 1:12 pm
Any tried and true method of unsticking gummed and corroded carbs ? So far after 3 days in carb cleaner, they look better but the slides are still stuck. I have also tried various lubricants but no go so far. I do have some evaporust that I plan on soaking next. Don't have any spares so I'm having to deal with what I got. Thanks.
PostPosted: Sat May 28, 2022 1:34 pm
Have you tried lacquer thinner or acetone?
PostPosted: Sat May 28, 2022 3:48 pm
Not yet Jim but I will add that to the process. Thanks for the suggestion.
PostPosted: Sat May 28, 2022 4:11 pm
If it's stuck with varnish from old fuel, either of those solvents should soften it.
PostPosted: Sun May 29, 2022 6:22 am
Yeah, it's mainly old fuel varnish.
PostPosted: Sun May 29, 2022 9:43 am
Acetone and/or laquer thinner has ways worked for me. You might have to soak the carbs for a bit, though.
PostPosted: Sun May 29, 2022 3:44 pm
That's 2 votes acetone. :D I'll pick some up and give it a go. Not in a rush just yet.
PostPosted: Mon May 30, 2022 8:52 am
Heat gun and they come right out…
1977 KH 400
1976 KH 250/350 rat bike
1971 KV 75
1976 KV 75
PostPosted: Mon May 30, 2022 2:58 pm
Got 2 out. 1 still stuck. I'll add heat to the process. Thanks Johnny.
PostPosted: Thu Jun 02, 2022 6:11 am
Victory. Got the 3rd carb unstuck. Now I get to try out my new ultrasonic cleaner.
