It is currently Mon Jul 14, 2025 8:48 am
 Post subject: Another oil thread?!
PostPosted: Sat Jul 31, 2021 4:47 pm
Ok, yes I started another oil thread but not asking "What is the best oil"?!
What 2 stroke oil do you use and where do you get it?
The Kawasaki dealer is 29 miles away and I never go there, just prefer to get it at local auto store or Amazon.
What is the NMMA, ISO Global, JASO or API identification I should look for? Not really a "SYNTHETIC GUY", my bikes get spirited riding but not raced or abused [shift at 8K rpm or below!]
Took the H1 for a ride yesterday, the oil tank was low, only oil on the shelf was [GASP] marine oil!
I said WTF, put a half quart in and had a great ride!!
 Post subject: Re: Another oil thread?!
PostPosted: Sat Jul 31, 2021 6:03 pm
I use generic TC-W3 oil, and usually get a gallon a Walmart. If they don't have it I can usually find it somewhere locally, or if necessary get a gallon off the Internet.
Some will be horrified because it's not for air cooled engines, etc., but with all the miles I've put on my H2 since I got it 43 years ago, I'm pretty convinced this oil is fine. :)
MrAxl's FAQ page should help: http://kawatriple.com/faq.htm#best_two- ... oil_to_use
PostPosted: Mon Aug 02, 2021 12:43 pm
Thanks Jim....agree with you that after 40 years, safe to say it's good!
I dont normally go to "Wally World" but can to pick up some oil.
Thanks
PostPosted: Mon Aug 02, 2021 9:33 pm
It's not important that you go to Walmart. The point was that it's generic TC-W3. It probably all comes out of the same tank car anyway.
PostPosted: Mon Aug 02, 2021 9:46 pm
Yama-Lube
PostPosted: Fri Aug 06, 2021 10:44 am
Maxima Super M Injector, specifically for oil injection. What difference is it to non injector oil? No idea.
PostPosted: Fri Aug 06, 2021 1:31 pm
injector oil is essentially 30wt oil and non injector 40w and above. important thing to note is premix only oil won't flow well in an injector system in cold temps where injector oil will :)
PostPosted: Fri Aug 06, 2021 5:08 pm
Oh, some good info there, thank you!
PostPosted: Sat Aug 07, 2021 10:10 am
I'll throw my hat in the ring:
Blue Marble
PostPosted: Sun Aug 08, 2021 9:11 am
Most important that the oil you use is blended for oil injection systems. Premix oils don't flow through the lines as well.
