It is currently Wed Apr 24, 2024 10:15 am
 Post subject: H2 carb bowl gasket
PostPosted: Tue Aug 01, 2017 8:09 pm
Does anyone know if the H2 carb bowl gasket shape is the same as a Mikuni VM34? Reason for asking, I am toying with replacing the carbs on my H2B and if the VM34 Mikuni bowl gasket shape was the same, I would be able to use the float bowls off my carbs with the oil feed fitting. The VM34 is quite a bit cheaper than the TM34, which I would rather have, but the possible bowl swap would seal the deal for the VM34 for me.
 Post subject: Re: H2 carb bowl gasket
PostPosted: Tue Aug 01, 2017 9:33 pm
the 34's are much bigger.
PostPosted: Tue Aug 01, 2017 11:04 pm
Ahh, thanks.
