There has been some discussion of UFOs on stock H2 carbs, and the fact that inserts that directly fit H2 carbs aren't available. Cody loaned me some UFOs, and from those I have some prototypes that we 3-D printed. The surface is not as smooth as the molded UFOs, but I don't know if that makes any difference at all. Mine are Nylon, and could be sanded a little to smooth them out some if it matters.
The consensus for other carbs seems to be that UFOs work best with 3.5 cutaway slides. Stock H2 slides are 2.5. We can make the inserts for any cutaway, but to try them without modifying stock slides, you'd need 2.5 cutaway inserts. It appears that for triples, when you order real UFOs, you get three 3.5 cutaway inserts, or three of another cutaway you specify.
It looks like the price would be $59 per set of three, postage included, which is about 1/2 the price of actual UFOs that are available for other carbs. If someone here who wishes you could get UFOs for stock H2 carbs is ready to try a set now, I'll cut the price in half if you report back about how they work. This obviously favors guys who live in the warmer parts of the US.
In case you're wondering about patent infringement, I checked on that before we started playing around with these. The patent has lapsed, so they're now in the public domain.
Here are a couple photos of a 2.0 cutaway insert in a stock 2.5 cutaway H2 slide. I just happen to have the 2.0 to take pictures of.
