Walms wrote:
I can take a look to see if it would worth while, but off the cuff, you could probably add 2" straight sections at the header and also add 2" in length to the belly without effecting the fit too much. It's something I can look into whether it's worth it to do power wise.
OK. Not bad. I was hoping I could get you to roll me some replacement sections reasonably cheap that I could use instead... along with instructions on which sections to swap out since I haven't welded anything up yet
From the graph it looks like a better pipe design for me... more power lower down. I was wondering what sections I would have to swap out to get the 110mm belly... probably the last divergent cone section, belly and first baffle cone section... plus looks like you mentioned another 2" added to the header pipes.
I was also going to try to rotate them and possibly section them a bit to try to work around adding my center stand back in. Think its possible to do?
Thanks
