It is currently Sun Apr 28, 2024 10:33 pm
 Post subject: air pressure in forks
PostPosted: Sat Oct 01, 2011 5:53 pm
My H2a came with schrader valves in the fork caps. Looks like a vintage mod add on. I've heard 10psi is a good pressure to use, but I'm want to know what my limits are as far as max pressure is concerned. I don't want to damage any seals or anything, but I would like to try higher pressures to stiffen the dampening. Does anyone know what my limits are or have a recommended pressure I should use for semi-aggressive street use?
PostPosted: Sat Oct 01, 2011 5:56 pm
Any pressure will reduce seal life. Under braking the psi goes over 100 psi already.
PostPosted: Sat Oct 01, 2011 6:01 pm
Really? That's good to know. Were the schrader valves and air pressure a gimmick? I guess my next question is how can I stiffen up the front end? Progressive Suspension doesn't seem to list progressive fork springs for my bike. Spacers on top of the spring?
PostPosted: Sat Oct 01, 2011 6:07 pm
They were a fad.
Call Works shocks and ONLY talk the Pierre in tech. You will need your dressed out weight and the bikes weight, and he will fix you up.
PostPosted: Sat Oct 01, 2011 6:10 pm
smoff83 wrote:
...I would like to try higher pressures to stiffen the dampening..
Damping is different from spring stiffness (spring rate) and spring pre-load (ride height). Are you trying to increase damping, get a higher spring rate, or change the ride height? (or some combination of the above?)
PostPosted: Sat Oct 01, 2011 6:33 pm
I'm not an expert when it comes to this, but here it goes...
Ride height is ok
the front sags too much when braking
when going into a corner, it feels like the front is "diving in" too much. I would like it to be more firm when cornering and my thought is I will have more control with a firmer front end. I think I just need more dampening an/or progressive rate springs
Thanks John. Is 423lbs, according to the spec sheet, a good number or should I get it weighed?
PostPosted: Sat Oct 01, 2011 6:43 pm
Actual weight plus rider.
When air was added about 6psi was used but different springs or added spacer length is better.
PostPosted: Sat Oct 01, 2011 6:46 pm
Get a true weight, the factory was usually way off. And there is no compression damping.
