It is currently Mon Jul 14, 2025 4:12 pm
 Post subject: Re: Kaw Bolt Codes
PostPosted: Thu Aug 01, 2013 10:58 pm
Dang Bobby, thanks for chiming in.
Thats exactly the info I was referring to.
:thumbup:
PostPosted: Fri Aug 02, 2013 5:36 am
Thanks, Bobby! That is exactly what I was putting together with holes filled.
PostPosted: Fri Aug 02, 2013 9:06 am
If we can get a few folks to send what they know it could help finish that chart. I was also starting to compose a list and have this much done for H2B/C so far.
Hardware: Fasteners, Dampers and Grommets
110BO0632 bolt, hex head 6x32mm (rear fender)
112BA0620 bolt 6x20 (voltage regulator, rear fender
112N0625 bolt, chrome plt. (master cyl, mtg. brkt.)
220AA0406 CDI assy. (ground wire attach)
220AA0510 screw, 5mm (ignition units A mtg.)
220AA 0514 screw (oil pump mtg.)
220AA0542 screw (oil pump mtg.)
220AA0535 screw (air cleaner pipe to carburetor clamp)
220AA0612 screw, 6mm (air cleaner cap)
220AA0635 screw (air cleaner pipe to filter housing clamp)
220AA0645 screw (stator cover)
220B0616 screw (oil tank mtg.)
311AA0600 nut, 6mm, supersedes 310B0600 (rear fender attach)
315AA042 nut (gear change lever bolt)
315B1000 nut, 10mm (chain adjuster bolt)
411AA0800 washer, flat (side cover bolt)
461F1000 washer, spring (rear shock absorber mtg.)
410AA0600 washer, flat 6mm, superseded by 411AA0600 (general purpose)
411AA0600 washer, thin flat, 6mm, (air cleaner assy., retaining bolt)
461F0600 washer, spring, superseded by 461DA0600 (oil tank mtg. bolt)
461DA0500 washer, spring
461DA0600 washer, spring
461DA0800 washer, spring (tail section mtg.)
461DA1000 washer, spring 10mm (shock absorber mtg., )
461F0400 washer, spring
482K5000 “e” cir-clip (kickstarter pin retaining)
550AA2015 pin, cotter (brake rod, rear footrest)
550AA0325 pin, cotter, (main stand, torque arm)
42045-005 nut, 10mm (rear sprocket mtg., 6 reqd.)
43030-001 bolt, chrome plt., superseded by 43030-002 (special offset for master cyl. lever adjust.)
44041-049 bolt, 6mm, chrome plt. (steering stem clamping)
46059-011 collar (clutch lever mtg.)
92001-121 bolt, hex head w/ crosspoint, 6x14mm, stock depleted, shipping different part
92003-015 bolt, (rear sprocket mtg., 6 reqd.)
92003-079 bolt, (side stand)
92007-040 bolt, chrome plt. (side cover fastening)
92007-002 bolt, chrome plt. (handle bar mtg. clamp)
92015-042 nut (swing arm bolt)
92018-004 speed-nut, 5mm (emblem attaching)
92019-021 nut, locking, H2B/C side stand bolt, rear footrest bracket (NLA, Use 92210-1184)
92022-116 washer, flat 6mm, superseded by 92022-1565 (oil tank mtg.)
92022-125 washer, flat 6mm (battery box bolt, tail lamp assy. mtg.)
92022-199 washer (footrest assy., rear)
92022-221 washer (footrest assy., front)
92022-227 washer, 7mm, rear fender mtg. (paired with 92075-133 damper)
92022-228 washer, 7mm, rear fender mtg. (paired with 92075-121 damper)
92022-246 washer, flat 10mm (rear shock absorber mtg.)
92037-072 clamp (fuel pipe, oil pipe)
92088-013 washer, lock, rear sprocket nut (3 reqd.)
92210-1184 nut, 10mm locking (side stand bolt, later models)
Rubber Parts
45017-012 bushing, rubber (shock absorber)
45017-015 bushing, rubber (shock absorber)
51077-007 gasket, rubber (fuel cock cup)
92075-252 damper (side cover bolt)
92071-082 grommet (oil tank vent pipe)
92075-222 damper (battery box)
92075-076 damper (battery box)
92075-078 damper (battery)
92075-252 damper, rubber (side cover retaining bolt)
3 H2's, all stock
H2B, converted to H2C
75 Paint & Decals by Brian H
75 Euro Seat by Tony O'Connor
PostPosted: Fri Aug 02, 2013 9:16 am
Another thing that would be useful to have as a reference maybe is the different dimensions of the various metal sleeves that sit in the rubber bushes - for battery box, rear gaurd etc etc. Especially as they could be readily made, if we but knew what to make. I'm hunting through all my bits back from the zincers and sometimes not sure of what to put where or what is missing that I am searching for in vain (for an H2C)
PostPosted: Fri Aug 02, 2013 9:23 am
Here is what I have so far. http://3cyl.com/mraxl/partid/list2/partcodes.htm
Some dimensions are included in the spreadsheet:
http://kawtriple.com/mraxl/files/parts.xls
and http://triplesdatabase.no-ip.com/
