IT'S ALIVE! http://www.kawi2strokes.com/forum/viewtopic.php?f=16&t=8839 |
Page 1 of 2 |
Author: | Ja-Moo [ Wed Jul 16, 2014 7:48 pm ] |
Post subject: | IT'S ALIVE! |
Carbs need work, they be leaking a bit, redo fuel lines, a few things like that. She revs nice though...... https://www.youtube.com/watch?v=NJ4jlFH ... e=youtu.be |
Author: | Walms [ Wed Jul 16, 2014 9:25 pm ] |
Post subject: | Re: IT'S ALIVE! |
She revs nice out of the box! Next I want a go-pro! |
Author: | falconman [ Wed Jul 16, 2014 10:08 pm ] |
So why can't we see the reed setup? |
Author: | evansje1 [ Wed Jul 16, 2014 10:12 pm ] |
Oh He|| yea!! |
Author: | Ja-Moo [ Wed Jul 16, 2014 10:59 pm ] |
It's on the build thread, right above this one......... viewtopic.php?f=16&t=8717 |
Author: | don k [ Thu Jul 17, 2014 2:48 pm ] |
Wow, lot of copper under those cylinders. Did you have machine a lot off the bases for repair or? Eta. for availability and cost. Are you going to race it or? Sounds good! Were you holding the pump wide open or was that just the idle position? |
Author: | Jim [ Thu Jul 17, 2014 3:25 pm ] |
don k wrote: Were you holding the pump wide open or was that just the idle position? You know John better than that. |
Author: | Ja-Moo [ Thu Jul 17, 2014 11:15 pm ] |
Don, It had a lift kit, with 2 gaskets and a .020" shim before. I replaced it with a .060" copper base for less trouble. And if you listen in the video, I said I hold the cam wide open to fill the lines. I re-geared last night, took the racing sprocket off and installed a 45 rear with a 15 front. Got all the street legal gear put back on and even found the plate sticker to put on. (old one was 2013... ) Reset a float as it was overflowing. Rebuilt the fuel lines today and fitted filters. I took her out today for a short run to get gas, clutch was dragging bad, and the carb started flooding worse. (found a chunk of "something" keeping the fuel needle from seating) Doodled a bit with the air screws after I got back, the 50's are way too big, so some 40's are going in. Not sure about the sytec, will doodle a bit more to see if I can stop the dragging. All in all, she runs nice so far........ https://www.youtube.com/watch?v=ocaxiEd ... e=youtu.be |
Author: | Dewman418 [ Fri Jul 18, 2014 1:44 am ] |
Very nice. |
Author: | Stumpy [ Fri Jul 18, 2014 12:41 pm ] |
John congrats on getting your 750 done! Sound's great and I can't wait to ride with you when you have the kinks worked out. And of course I will supply you with ear plug's for my stingers.... Second thought I should ride the 500 so you won't bust my nads! |
