It is currently Mon Jun 16, 2025 2:44 pm
 Post subject: Lightening Brake Rotors
PostPosted: Thu Dec 19, 2013 11:59 pm
Hey guys!
Thank you in advance for the advice. I'm sorting my '75 H1 and I am concerned with the weight of the front brake rotors. 6lbs 10oz each!!
I want to cut them down and then drill.
My question is how far can you cut these thinner before they're junk? Spec is 6mm but I still think that is too thick. Anyone done this yet?
PostPosted: Fri Dec 20, 2013 1:40 am
I don't like to go less than 5.5. with a single disc, but some have gone to 5mm. Get a EX 500 caliper and you can remove a bunch of unused disc.
PostPosted: Fri Dec 20, 2013 2:26 am
Looks kinda like this:
Don
PostPosted: Fri Dec 20, 2013 6:41 am
am full brembo front: the whole kit, double discs, calipers, master cylinder, hoses, 8-) is a little lighter than a genuine single disc
PostPosted: Sun Dec 22, 2013 5:46 pm
If you want to get serious and drop some weight off of your rotor you can do this.
PostPosted: Mon Dec 23, 2013 10:00 pm
What kind of hub is that?
They always run best right before they stop for good...and it was just running great...
PostPosted: Tue Dec 24, 2013 1:42 pm
Picked up some old rotors of an old 600 cc bike. They are original and just 3.5 mm thick.
Even at this thickness, they do not warp over overheat.
There are some calipers around with rather tiny brakepads, having friction material of just a 1 inch high.
While most pads are close to 2 inch high you can machine a lot of material of the rotor and safe even more weight.
Speed is what’s life about.
PostPosted: Tue Dec 24, 2013 2:58 pm
Stock H1/H2
PostPosted: Tue Dec 24, 2013 4:52 pm
How nice is that! :clap:
PostPosted: Wed Dec 25, 2013 9:39 am
Oh...I see it now. Very, very cool :clap: :clap:
