It is currently Thu May 01, 2025 1:45 am
 Post subject: fork emulators
PostPosted: Thu Oct 31, 2013 1:45 pm
Can you guys clarify for me what the PVC spacers do? Just so i can clarify in my brain what i am attempting to accomplish while i am working.
And is there any better way to modify the holes that need to be drilled on the bottom besides welding them closed? Can they be JB welded or bolted? The directions are VAGUE!!!!! :roll:
Finally got my bike out for a ride last weekend for about 50 miles with NO issues!! rode to a vintage swap meet and was famous as i rode in!!!! :clap:
Thanks!!
 Post subject: Re: fork emulators
PostPosted: Tue Nov 19, 2013 7:31 pm
I've used high-temp acid-core solder to plug the holes. You only need a propane torch to do it. I suppose you could drill and tap the holes and put a set screw in the hole, but that's doing things the hard way. JBWeld might work...
Lane
PostPosted: Tue Nov 19, 2013 7:49 pm
The spacers are to adjust spring preload, if that's needed.
PostPosted: Wed Nov 20, 2013 5:33 am
Thanks!!
Take a look at the text I have highlighted in this document from Race Tech:
https://dl.dropboxusercontent.com/u/399336/Pictures/Posted/Emulator_Fitting_Requirements.pdf
Based on this I decided to modify my piston rods as shown in the following picture.
The instructions I received called out for 6 ea. dia. 6.35mm (1/4’’) holes which is a total area of 190mm^2.
Instead I decided to just add a second set of holes just above the existing ones which means I have 8 ea. dia. 5.5mm holes, also with a total area of 190mm^2.
Obviously, this doesn’t weaken the rods and I didn't have to weld or braze.
PK
PostPosted: Tue Nov 26, 2013 1:36 am
:thumbup:
PostPosted: Sun Dec 08, 2013 3:44 pm
Thats funny. Most comon line of thought is that stock forks of triples are underdamped.
To increase compression damping, two of the four holes at the bottom should be closed to get some compression damping.
And from the two 2 mm holes which gouvern rebound, one gets closed and the other one reduced to 1.5 mm.
The reason why racetech suggests to enlarge to lower holes is to prevent disturbing their alternate system fitted higher up.
Speed is what’s life about.
PostPosted: Sun Dec 08, 2013 4:22 pm
Maybe it's just me - but over the years with all my bikes I've had good luck just varying the oils and/or amounts - little more/little less.
PostPosted: Mon Dec 09, 2013 6:21 am
I have just add a spacer on the fork and heaviest oil :mrgreen: perfect for a road bike 8-)
PostPosted: Mon Dec 09, 2013 9:37 am
I'm not going to argue with the experts here, but I thought the whole idea behind the Gold Valve was to replace the stock compression damping with a more sophisticated system.
So, instead of squeezing oil through holes you are squeezing oil through an adjustable spring loaded valve.
PostPosted: Mon Dec 09, 2013 9:50 am
Did mine similars to PK's
92 NSR250 MC21, 93 TZR250 3XV
03 ZRX 1200R
