Walms wrote:
Looks like things are coming together Dan!
I'm looking forward to seeing this funky layout you have planned for the pipes!
Coming together like molasses in the freezer.
Not sure what form the pipes will take.....soon they will look like something
They were super impressed with your kit Andrew....top notch was the phrase. I sorted and laid everything out and the welder was smiling.......I told him to read the print on the flanges because its a Rubik's cube to me
"You aren't holding back on the "trick" bits, thats for sure."
Well Cody, it's "man overboard"
I don't think I will ever build another bike this in depth for lack of a better term. I want to do it with a happy result.
"Dan, what process did you use to get that finish onthe hubs? They came out really nice."
Thanks. A quick touch with 80grit white glass at about 80psi and a long/slow hit with fine walnut at 100 psi. Brillo pads dripping wet always back and forth evenly all around with pretty good "pressure". The last was maroon scotchbrite pads one direction only with as much "pressure" as I could use.
