It is currently Fri Jul 11, 2025 1:38 pm
 Post subject: 72-3 H2 swing arm mods?
PostPosted: Sun Jan 06, 2013 11:10 pm
I have a extra 72 H2 swing arm that I'm getting ready to send to the powder-coaters. What about adding needle bearings (KZ900), what does that improve.
I have new bronze bushings but wondered if I should ad a brace to the front section?
PostPosted: Mon Jan 07, 2013 12:02 am
Bronze bushings actually have more contact area, and if lubed once a year, work great. Rollers, with such small deflection really aren't any better, if at all. I haven't seen any need for bracing, and it would be the back arms that would more likely flex, but that would take some good loading.
PostPosted: Mon Jan 07, 2013 2:32 am
That sure makes me wonder why 95% of all bikes (500cc and above) in the last 30 years uses needle bearings in the swing arm. It sure isn’t the cost.
I have 10 years and 50k miles on my swing arm needle bearings (H1E) and there’s nothing to indicate that I would need to replace them any time soon.
PK
PostPosted: Mon Jan 07, 2013 2:47 am
Needle rollers work fine, and so do bronze bushes, it's a bit like the tapered/ball head-stock bearing thing. I'm sure a lot of bikes have been fitted with needle rollers for the marketing kudos! I don't think a swing-arm is the best application of needle-rollers! Just 1 opinion. :)
