I run a single Speedhut 4in tach on my H1A (with battery/distributor CDI). Try to rubber mount the tach to keep as much vibration away for the unit. I'm starting to see the face buzz within the unit on mine. I'm sure my bent crank did not do the tach any good either!
A few tips from my post from another thread to get electric tachs to work on these old bikes:
The issue which cause problems is excessive ambient RF noise from the HT circuit of the iggy and/or noise within the signal circuit to the unit. The first thing to do is to try to clean up this input signal. Jim at Lakeserve makes a tach adapter that connects in series into one of the coil wires low tension circuit. This is a purely inductive device (has no effect on power to the coil) with a built in zener diode that clips the voltage to about 12V. I run this unit on my H1A.
Walms and Jim both run the Veypour digital units. As far as I know the above is the only mod Walms has done (H1D/H2 iggy). Walms does have the KH400 metal shielded spark plug caps though.
MSD also makes a tach adapter that it too is an inductive device that also clamps onto the low tension coil supply. This one however triggers a battery supplied spike to the tach.
If the above is not enough the next step is to install Ferrite beads on all wires (especially the sense wire) leading into the tach. Try to get the larger beads (about 1.5 inches long) and you can get two or more turns through the core. Last reported Jim runs with his tach adapter and ferrite beads on his Veypour setup with good results on his H2.
If the above combo is still not enough you will be forced to run resistor plugs. The R plugs have 5K resistance. NGK states the closer to the actual spark the resistor is placed, the better the RF suppression. Nev Lush has in the past installed NGK 5K ohm resistor plug caps on his race bikes.
I have been running the R plugs or plug caps without issue for at least two seasons. I still occasionally have the tach act up (goes erratic WFO top of fourth) and may have to go to 1K caps with the R plugs (H1A distributor CDI).
