It is currently Wed Apr 30, 2025 7:48 pm
PostPosted: Sat Oct 01, 2016 11:10 pm
Wondering what way to go for small rake (castor angle) and trail improvements on my H2B. On my XV750 to go from cruiser with too much rake to cafe that handled MUCH better, I lowered the front and raised the rear, steepening the fork angle. Somehow think the H2 has too much rake now, but it does have steering dampers that seem to indicate it has problems with too little rake. Thoughts?
PostPosted: Sat Oct 01, 2016 11:20 pm
Longer rear shocks, raise the fork tubes slightly in the triple clamps, and I don't know if an early (shorter) H2 swing-arm will work in a H2-B, some guys have done the reverse, though I am not sure why! A lot of people use an 18" rim on the front too, with good results. Careful set up is the key to good H2 handling. (standard rake is something like 27.5 degrees, you can afford to bring it in a little....)
PostPosted: Sun Oct 02, 2016 1:38 am
There is a cool rake trail calculator on Dale resource site listed at the top of the board. Rod is correct A 18" front makes a difference and longer shocks. Check what your actual rakes is and use the calculator to get 100 mm of trail, that works really well on the H models. :thumbup:
PostPosted: Sun Oct 02, 2016 1:47 am
I'm doing the 18" front wheel on my H1, have read nothing but good on that mod :thumbup:
PostPosted: Sun Oct 02, 2016 9:21 am
Plus it increases the disc advantage....... :thumbup:
PostPosted: Sun Oct 02, 2016 8:59 pm
What is the suggested 18" front rim to use, to lace up to the stock hub?
PostPosted: Sun Oct 02, 2016 9:44 pm
If you're asking what's the best one, I'd say get an Excel. I built a wheel with one and it almost trued itself. Check the recommended width for the tire you want to use. 100/90 is a decent choice.
PostPosted: Sun Oct 02, 2016 9:46 pm
Rake or 18 inch wheel :think:
PostPosted: Sun Oct 02, 2016 10:34 pm
Disc, the ratios of diameters are closer. I also use a 100 front with a 2.15 rim width.
PostPosted: Mon Oct 03, 2016 6:58 am
The wheel being an 18 inch gives the caliper a little more stopping power over the same setup on a 19 inch wheel :?:
