Then this portwork is done. 260 mains, P5, 6DH2 mid position on this last dynorun. No air filters. Warm oil, warm crank, "half warm" cylinders.
I am happy with the reseult. Especially peak power at quite low 8000 rpm. Don't need a whole lot of rpm to get the power as long as the portwork is ok, with ok torque.
Powerband starts at quite low 5300 rpm. 34 HP. No significant flat spot in mid range. Should be very streetable, and can give full throttle from 3000-3200 rpm.
90 Nm torque at about 7200 rpm. Satisfied, as I don't exactly get any help from the SpecII pipes. Overrevv is very good, she even peaks up a bit around 8600 rpm. That means, when changing gear at 9000 rpm, you actuallly hits the very sweet spot at around 8000 and have 95rwhp at once. Don't know why this happened though, must be a residual pulse. My estimate if jollymoto was used for this set-up..........at least more then 100 rwhp.
Not a perfect dyno sheet, but ok in my opinion. Others may say I have a lot learning left, and the one with problems. Should I care?
Thank you all for following this thread. More projects like this will follow, as there are some reeded and ported cylinders around here as well that needs to be looked into.
Joe: Your specII pipes are not the reason behind your flat spot as you can see from this quite heavily ported H2 dyno sheet, and definitely not at 5252 rpm (stock ignition by the way) but I guess that will be questioned later on.
Below is the final dyno sheet for this project: (90 Nm is 66,38 ft/lbs)
Below is a sound clip of my own H2, modified Jollymoto. I like the sound of my first H2 project. It has as best 124 rwhp. Estimated power at video, around 115. Hits the rev limiter in third at 9200 rpm (about 100 mph) as you can hear. Gearing is 14/47, that is about 17% heavier gearing then a stock 15/45 H1.
Turn up the volume
(sound like a 100 years old tractor on idle though, only 800-900 rpm.
Jørgen
