It is currently Sat Jul 12, 2025 12:39 pm
PostPosted: Wed May 22, 2013 4:47 pm
The denco stage one is 29.5mm, so you should be ok, it "might" be a little doggie on the bottom.
PostPosted: Wed May 22, 2013 5:07 pm
Oooops, Hello Mr. Learning Curve again! Before long, I'll be familiar enough with him to call him Learn for short. :lol: I measured the height of the port itself, not the distance down from the top of the cylinder to the top of the port. Am I understanding that correctly? I should be able to snick into the garage long enough to measure that and let you know. Thanks again for educating me!
PostPosted: Wed May 22, 2013 10:45 pm
I measured from the top of the cylinder to the top of the exhaust port and got 26mm :-o It looks like I am in the market for a set of mostly stock cylinders, since I want this as a streetable bike - what is a reasonable price? Thanks in advance for any input.
PostPosted: Wed May 22, 2013 11:18 pm
Yep, major porting mistake......
PostPosted: Thu May 23, 2013 12:28 pm
Do I need to measure the piston too, if I am at it, in case they have been hacked on too?
Thanks, Phil
PostPosted: Thu May 23, 2013 1:05 pm
Both skirts should be the same length......
PostPosted: Thu May 23, 2013 6:55 pm
I might be able to hook him up. I hate to see an S3 sitting. :thumbup: Check your PM Phil.
PostPosted: Mon May 27, 2013 1:29 pm
A big thank you to Richard on hooking me up on the stock cylinders. :thumbup:
Mark came over yesterday and we think that the piston skirt had been cut, but in a lathe, all the way around instead of the typical grind only the port area. The skirt has sharp corners at the transfer ports and there is a rabbet or relief turned into the inside of the skirt.
So, we measured from the bottom ring to the bottom of the skirt and got 49mm. Now I just have to see how that compare to a stock piston.
PostPosted: Mon May 27, 2013 2:14 pm
The stock piston measures 58mm from the edge of the dome to the bottom of the skirt. ;)
PostPosted: Mon May 27, 2013 3:29 pm
Phil, I measured a stock piston at 49mm from bottom of skirt to bottom of bottom ring so it appears that your pistons have not been modified. ;) Also that "step" is there on all the stock 400 pistons I have.
