It is currently Wed Apr 30, 2025 8:28 pm
PostPosted: Thu Jun 09, 2016 10:31 am
Hi all
I am running a set of Ja-Moo reeds and running a set of TM 34 Flat slides. my problem is the float bowl is to tall.
the center carb it hits the neutral switch.
PostPosted: Thu Jun 09, 2016 10:39 am
I suppose you could make a plug to replace the neutral switch and do without it.
PostPosted: Thu Jun 09, 2016 10:47 am
34's are a tight fit, sometimes you have to fudge around a bit. I did what Jim suggested, but you can also safety wire the bell to pull it up a bit to clear the switch. Sometimes a bit of clearancing on the case top and bowl drain plugs is needed also.
PostPosted: Thu Jun 09, 2016 10:51 am
72zx7r wrote:
Hi all
cancel it and fit a flat plate instead
PostPosted: Thu Jun 09, 2016 11:20 am
Hi
I have some small aluminum flat stock.
Thanks for your input
PostPosted: Thu Jun 09, 2016 12:02 pm
I have TM34's on my H2b. only clearance issue I had was the left float bowl drain plug contacting the case. I ground the head of the plug down to fit. Are you using stock intake manifolds? I had some aftermarket ones that were longer than stock that caused problems, I ended up not using them.
PostPosted: Thu Jun 09, 2016 9:31 pm
This is what I am useing
Mikuni Rubber Flange Adapter Manifold 75mm Bolt 40mm Spigot 990-842-007
http://www.ebay.com/itm/171361033368?_t ... EBIDX%3AIT
PostPosted: Fri Jun 10, 2016 7:12 am
I'm using stock intakes. The 34's will fit, might have to wet them. The carb / float bowl after its installed is located well forward of the neutral switch.
PostPosted: Wed Jun 15, 2016 8:05 am
When I used the TM34's I had stock intakes - no clearance issues.
PostPosted: Wed Jun 15, 2016 1:22 pm
I agree with the others, you need to use stock manifolds. A little bit of WD40 or silicone spray and they will go right in with the clamps loosened up. Then you can keep the neutral switch.
