It is currently Tue Jun 04, 2024 4:01 am
PostPosted: Fri Jul 15, 2011 7:56 am
With reference to Kaw bulletin 73H-16 (oil pump cover update):
You have stated you used to trim the end of the early covers on a lathe to correct the o ring seep issue, which the above service bulletin addresses.
How much material did you remove from the end of the early covers?
PostPosted: Fri Jul 15, 2011 10:59 am
You mean this one:
Bulletin#: 73 H-16
Date: Oct. 20, 1972
Bike(s) affected: H1, H2
Subject: Oil pump modification
Action taken:
PROBLEM: There is a tendency for some three cylinder models to smoke excessively from one exhaust pipe. On the H1 and H2, it is usually the right cylinder that is affected.
CAUSE: This problem has been traced to faulty O-ring seating in the oil pump end cover. After installation, the two O-rings inside the cover shrink approximately .1 to .2mm in diameter. This shrinkage allows oil to seep around the seals and into the end cover chamber. From this point, the excess oil is pumped to the right cylinder which is serviced by the end cover orifice, resulting in smoking and premature spark plug failure.
It should be noted that other symptoms may indicate oil pump malfunction, such as right hand piston seizure. This may be caused by oil being forced back into the main pump body through defective O-rings. As a result, the right cylinder is starved for oil, and this situation will eventually lead to seizing.
CURE: To remedy this problem, the oil pump end cover has been redesigned to prevent oil seepage.
A. The radius in the end of the cover has been decreased in depth to give the O-rings less "squish" space.
B. The bottom radius has been eliminated.
C. The internal diameter of the chamber has been decreased from 14.0±.1mm to 13.7±.05mm to compensate for shrinkage.
D. A slight shoulder has been added to the chamber base to further compress O-ring.
A conversion kit is available to correct older model oil pumps. The kit consists of two mounting screws, two O-rings, and a new oil pump end cover. These parts will fit all three cylinder oil pumps. Conversion kit P/N 99990-016. IMPORTANT: Whenever an oil pump is disassembled for any reason, the O-rings must be replaced. The end cover O-rings are P/N 16090-002.
This issue wasn't about diameter of the O ring as much as it was about the "crush" distance of the O ring between the oil pump body sealing surface, and end cap sealing surface
This was/is a common problem with the H and S series pumps. The sealing O rings on the output cap end of the pump get "sacked" (make themselves into an oval, and decrease in overall diameter, and allow pumped iol to migrate back into the pump chamber, away from the output port. What the factory did, in effect, was to devise a revised replacement end cover and send new O rings with it, in a kit listed by p/n above. The revised cover literally had a smaller area and profile that would not allow the O ring to become compressed, eliminating the back leak form the outlet port to the pump chamber. This restored correct oil metering to the right cylinder, if I remember which one it was correctly, from memory.
What all this means is, the end cover was trimmed down and the radius inside it reduced, to hold the O ring in more tension, and not allow it to change shape and leak. This can be done to early non-modified end caps as well, simply trim about 0.80 to 1.00mm (appx. .032 to .040 inch) off the mating surface of the end cap, and install a new O ring, should work as well as the factory modified cover, and clear up the problem/issue. I used to cut the end cap on a lathe, but, since than, I have made a fixture for my milling machine that holds the cap with the sealing end upwards, and plunge cut the end of the cap with a mill boring tool/index head. Sounds complicated, and care MUST be used to get the cut right, so the end cap/O ring seals correctly, but it isn't rocket science/brain surgery.
DO NOT MODIFY THE OIL PUMP BODY, NOR THE GREEN ANODIZED PISTON GUIDE SLEEVE INSIDE IT, THEY ARE NOT THE PROBLEM.
A very crude visual example of what happens is such:
Take your index finger and thumb, and make a circle of them, THIS is what the O ring looks like new. To replicate what the O ring does, extend both that index finger and thumb, and move them straight out from your palm, parallel with each other, spaced apart, creating two flats of the finger/thumb. Both flats are what happens to the O ring, becomes flat on the sealing sides (body to cap), reducing the sealing tension on the O ring, allowing the leak. The modded cover simply puts more "squish/crush tension" onto the O ring itself.
PostPosted: Fri Jul 15, 2011 11:46 am
So then would a thicker diameter o-ring accomplish the affect as the oil pump conversion kit?
PostPosted: Fri Jul 15, 2011 12:06 pm
OK, .032in-.040in off the mating surface of the pre-modded caps.
Thanks 'Tuner
Mike, I suspect the next available larger cross sectioned O ring would be too big, hence Tuner's requirement of the machine work to the cap...
Dale, This tip/dimension would be good to archive in your site! :D
PostPosted: Fri Jul 15, 2011 12:22 pm
Seems you could use some thin shim stock and a new o ring, and not have to machine anything.....
PostPosted: Fri Jul 15, 2011 12:43 pm
H2RTuner wrote:
You mean this one:
Bulletin#: 73 H-16
Date: Oct. 20, 1972
Thanks for the information, Dave. I have overlooked this bulletin for 33 years, and I'm now thinking that the oversight may be responsible for my right piston always being the one to rattle first, and my right cylinder always the one with the most scoring a few thousand miles after a top end rebuild.
Your do-it-yourself modifications are straightforward, but because of my backlog of work, I searched around for the kit, number 99990-016. Vintagekawasaki.com, in Canada, says they had six in stock at $30 each, so after my order for two kits, they're down to four in stock.
It would be great if my next top end's right piston lasted as long as the center and left ones!
PostPosted: Fri Jul 15, 2011 2:27 pm
Done!
PostPosted: Fri Jul 15, 2011 2:46 pm
Three left - I just bought one. Thanks for the tip Jim and info from Dave. Funny when you look at the picture - and then at a pump I go "ahhhhh that's where it goes". I never noticed the end of the pump before (I have 3 pumps - never gave it a second look).
Not that I care a whole whole bunch - but extended stays on the kick-stand could explain years of right cylinder noise. I'd like to get some more quiet time with my Wossners though :mrgreen:
PostPosted: Fri Jul 15, 2011 10:27 pm
I haven't modded a pump end cap for years, but if memory serves me right, and that is very dicey, the O ring is a pantogram, isn't a simple O ring, it is a mounded to fit the odd shape ring.
If you use a shim to compress the O ring further, the shim would sit against the metal, and being metal, wouldn't seal, UNLESS you ran two O rings, and built the pack oil pump body - O ring - shim - O ring - end cap.
Just something to think about, and check out as well.
PostPosted: Fri Jul 15, 2011 10:33 pm
Now down to two...
