It is currently Fri Jul 11, 2025 3:03 pm
PostPosted: Thu Nov 08, 2012 1:12 am
PostPosted: Thu Nov 08, 2012 1:47 am
You've omitted the spacer plate that is supposed to go with the base gasket(s)?? :lol:
Looks like you may be contacting Lani for a custom thickness base gasket or head gasket..... ;)
PostPosted: Thu Nov 08, 2012 2:33 am
Did your cat build that engine............? :?
PostPosted: Thu Nov 08, 2012 3:34 am
Those are my QC stickers........ :lol: :lol: :lol:
And there are no spacers........ :wtf:
PostPosted: Thu Nov 08, 2012 4:35 am
It's not a left barrell where a left one should be?
It's too shiney for you, too, moo?
PostPosted: Thu Nov 08, 2012 4:44 am
It's a H1-R engine - 3 centre barrells................!?
PostPosted: Thu Nov 08, 2012 8:48 am
The fleck of dirt on the 4th fin down is not centered exactly, if that it? :lol:
The gouge in the left side engine cover mating surface? :wtf:
OK, I've seen decked cylinder blocks present the same issue, and either a spacer or thicker base gaskets are used.
Then again, maybe it's a stroker crank! :thumbup:
steve
PostPosted: Thu Nov 08, 2012 11:45 am
I saw a similar thing years ago when someone convinced me that certain snowmobile pistons would fit. they did, and the piston pin was in a different location. :banghead
PostPosted: Thu Nov 08, 2012 5:42 pm
I's not a a kawasaki cylinder....looks too tall.
PostPosted: Fri Nov 09, 2012 12:57 am
I'm at a bit of a loss on this one. The cylinders were decked so much the piston is 1mm proud, and the heads are step cut 1mm. I have only seen this when trying to compensate for too much port timing, but the timing is very mild. So it's not making a lot of sense................ :eh:
Users browsing this forum: concours
