It is currently Sat Jul 12, 2025 8:35 am
 Post subject: Correct Battery for H2B?
PostPosted: Wed Aug 22, 2012 9:16 pm
Obvious noob question: Current replacement battery is quite a bit smaller than the stock H2B battery box. Probably should look to see if it is 12V/6AH or smaller or just what it is. Recommended source for a good 12V/6AH which will fit the battery box? Local MC dealer or Walmart, etc.?
Thanks, Rusty34
3 H2's, all stock
H2B, converted to H2C
75 Paint & Decals by Brian H
75 Euro Seat by Tony O'Connor
PostPosted: Wed Aug 22, 2012 10:16 pm
Get any decent one you like, and if it's too small for the box, use foam rubber to make it snug. I'm using an AGM battery in my H2, with foam all around.
PostPosted: Thu Aug 23, 2012 5:34 am
I bought one of these for my triple. ( yellow battery ) Fit perfectly.
http://www.impactbattery.com/batteries/ ... 1972-1975/
PostPosted: Thu Aug 23, 2012 6:33 am
Stay with an AGM battery so you don't get battery acid out gasing and spilling out on the bike.
PostPosted: Thu Aug 23, 2012 8:08 am
just take the good one according to the positive and negative wiring position , means the positive should be on the front on the battery (near the side cover) and the negative at the rear if my memory is good, if you don't the wire on the wiring harness could be too short :mrgreen:
