It is currently Sat Jul 12, 2025 3:54 am
 Post subject: exhaust design question
PostPosted: Sun Aug 12, 2012 3:04 pm
Since I put the H1 engine on the suzuki frame I had to modify all 3 aftermarket pipes.
I had my local welding shop do this. The outer pipes had a tiny wedge cut right after the front curve. Then were rewelded so the over all curve was brought up an inch or 2 depending on the pipe.
But my middle pipe was cut to have the angle raised and rotated a little.
All my cylinders have the same compression. But the outer pipes have a nice pressure pop to them at idle, and the center pipe doesn't. I am assuming I lost some design quality to the center pipe by modding it.
Any ideas how I could fix this problem when i tear it all down this winter?
I have tried jetting, packing and all that. I am pretty sure it is from my mod. Maybe a ridge from the weld on the inside?
PostPosted: Sun Aug 12, 2012 3:43 pm
Your center pipe feeling different at idle is not caused by small changes made to your expansion chambers. Clogged pilot circuit, or bad sync, etc., are more likely causes.
PostPosted: Sun Aug 12, 2012 4:05 pm
I have re synced them many times.
Clogged pilot circuit...hmm I will have to give that a try.. It does seem to make a difference when I turn the air screw though.
PostPosted: Sun Aug 12, 2012 4:35 pm
Good call Jim, I switched the center and right carbs around and the problem followed the carburetor.
PostPosted: Sun Aug 12, 2012 4:39 pm
A pilot jet can plug in a short amount of time with today's crap gas. Just be glad you don't have to run the stuff they sell in Ca. and have to pay .50
more a gallon than any other state :banghead
