It is currently Wed May 14, 2025 11:32 pm
 Post subject: Less than half power
PostPosted: Mon Jul 23, 2012 11:42 pm
I have a 73' h1d and it starts easily and idles and revs great. The problem is it seems to not get enough gas because it revs up to about 4 grand and then has a moan to it after 4 grand and no power after that. There is plenty of smoke at wide open throttle which I guess is the injector is pumping what it should but I'm thinking it's not getting enough fuel. Ive had the carbs off twice and cleaned them really good with carb cleaner and compressed air. I took a compression check and all cyls were at 152 lbs. Any thoughts would be cool. Thanks!
 Post subject: Re: Less than half power
PostPosted: Tue Jul 24, 2012 12:20 am
Did you try bigger main jets?
PostPosted: Tue Jul 24, 2012 12:30 am
No, these are what came with the bike. I have no knowledge of jet sizing for these bikes. Is it possible to actually have undersized jets? I figured the least I would have is stock ones. I do however have expansion chambers if that means anything.
PostPosted: Tue Jul 24, 2012 1:27 am
If its been standing for a year or two you need to strip the carbs down, all the jets out and cleaned till you can see through the holes (you might need to push a pin through to clear) just carb cleaner and air will not do it while in place
PostPosted: Tue Jul 24, 2012 1:40 am
You have to jet for any motor modifications. Especially expansion chambers. So yes, undersized jets can melt a motor.
Memorize this page http://kawtriple.com/mraxl/carb/carbadj.htm
PostPosted: Tue Jul 24, 2012 7:03 am
Other things to check and in this order (IMO)
* Clogged air filter
* Clogged stock exausts (remove and clean; I use kerosene or mineral spirits)
* Ignition timing
PostPosted: Tue Jul 24, 2012 9:01 am
I want to add that it could be a goobered up petcock that just won't flow enough fuel.
You should check everything to avoid burning up a piston.
Rotortech
Indianapolis
1974 S3
