It is currently Sun May 11, 2025 3:08 am
 Post subject: A few questions
PostPosted: Thu Jul 19, 2012 4:59 am
How long is the H2/H2A Rear brake rod,
also on H2B/C side panel dampers 92075-252 not avail anyone tell me what length they are, need to make some up TIA.
 Post subject: Re: A few questions
PostPosted: Thu Jul 19, 2012 7:16 am
My H2 rear brake rod is 505mm long, overall! Can't help with the dampers!
PostPosted: Fri Jul 20, 2012 12:12 am
Thanks for that. I bought a NOS Brake rod was marked as H2 but the part number came up as Z650. It is 496mm long so I expect can be used on an early H2.
My H2C is way longer so it can't be used on that though due to extended swing arm.... it can fit but the rear brake arm is way off the correct angle so should be fine for H2.
