It is currently Wed May 14, 2025 7:46 pm
PostPosted: Thu Jul 05, 2012 2:17 pm
Finally got this H1 on the road...It feels fine until after 5 minutes of riding. Then while cruising I feel it surge. And if I get on the throttle it feels like it take a second to over come something dragging. If I pull the clutch I can tell it isn't a wheel bearing or brake dragging. I am experienced with carb jetting, it isn't that. It really feels like a transmission bearing tightening up intermittently. But I don't hear any strange noises at all.
Anyone got an idea of what this could be? this is very intermittent.
Or could I be miss interpetting a bad clutch /broken clutch plate? It does slip if I get on the throttle hard.
PostPosted: Thu Jul 05, 2012 2:43 pm
Drive chain alignment?
PostPosted: Thu Jul 05, 2012 2:46 pm
Brakes?
Rotortech
Indianapolis
1974 S3
PostPosted: Thu Jul 05, 2012 3:08 pm
You mention surging and lagging throttle response, so why do you rule out a lean spot?
PostPosted: Thu Jul 05, 2012 3:39 pm
I don't think it is jetting because I was working on the jetting all yesterday because it was very rich on the bottom. And it really feels like the motor is trying, but something is dragging. I am confident in the jetting, i got it just lean enough to stop fouling plugs, but maybe a crank seal going in and out of leaking?
And it doesn't feel like the brakes or anythingthe not engine related when I pull the clutch.
PostPosted: Thu Jul 05, 2012 3:47 pm
I'd raise the needles one notch (lower clip, of course), just as a test, and see if the problem changes. It sure sounds like a lean mixture. Put some tape on on your throttle twist grip and mark 1/8, 1/4, 1/2, 3/4, and then you can see where the problem is.
PostPosted: Thu Jul 05, 2012 3:51 pm
sounds like the best next step, I had the needles there but don't remember if it did that or not. But fouled plugs. I hope it isn't a crank seal leaking.
:thumbup:
PostPosted: Thu Jul 05, 2012 4:13 pm
A leaking crank seal wouldn't cause symptoms that come and go.
PostPosted: Fri Jul 06, 2012 12:25 pm
I think i just figured it out.
The back brake was dragging a little. I took it apart and cleaned it.
But jetting....This thing, the outer carbs are H1 D/E set ups, and the center carb is a H1 C set up. Which run different needle jets and i had the one off sized needle in the wrong carb. I haven't tried it yet since putting the needles in the right carbs. But i bet this solves my problem.
EDIT. well the H1 C takes a part number 3 throttle valve and i have all #2s
PostPosted: Fri Jul 06, 2012 12:43 pm
The H1C carb runs in an vastly different environment than the later carbs (Different ignition timing, mufflers (back pressure) and intake filiter/tract).
I suggest you change all the internal carb parts to match. Late model carbs are plentiful on evilbay.
