That's good news.
After removing the broken cylinder on mine, there were two things I learned. (at least
) The ATF/acetone, PB Blaster, KROIL (expensive) did not penetrate the length of the stuck studs at all, in spite of numerous cycles with the torch, hammering the studs with the nuts screwed on several thousand times etc. No penetration. And they were so corroded that breaking away the aluminum, the outer layer of rusted/corroded steel remained stuck to the aluminum. The studs that were stuck looked like a hurricane Katrina flood victim, but the bike is actually quite clean-go figure.
Anyway, I'm glad you are done with that part. I've pulled studs for mine from another old set of cases, have two new cranks, rebored cylinder and pistons for both. Frames going to powdercoat this week I hope.
John
