I'll be getting ready to start my fresh rebuild motor on my H2B (rebuilt crank, new pistons, Expansion pipes, Uni Air Filters, etc)
I read this link below and was extremely insightful and just wanted to recap and see if everything is covered:
viewtopic.php?f=13&t=2026&hilit=first+start+motorPre-Start Check List (In no appearant priority listing)- Motor grounded
- Float levels set/Carbs cleaned/Initial sync'd
- Repack silencers
- Check oil in reservoir for obstructions/Bleed oil line to pump/No need to pre-mix
- Check kill switch operation
- Check throttle cable operation
- Oil in Tranny (1-1/2 Qt)
- Dino oil in cylinders (does this apply to honed walls and WHAT IS DINO OIL)
- Petcock set on Prime
Post-Start Check List (no particular order)- Hold oil pump to MAX/Bleed lines to carbs/crank
- Set carb idle
- Set timing w/light
- sync carbs
- check charging circuit
- Re-torque heads/exhaust collars for 3 heat cycles
Is that about right?
What is DINO oil? Is there an equivalent?
How many miles to break-in? Under 5K RPM?
Let me know if i've forgotten anything important. Thanks. And yes I will say a small prayer in advance as well..........
