Hal wrote:
Did you line up the marks on the spring plate, as it only goes on one way properly?
It is the reduced throw that makes the replacement actuator easier to use - reduced gearing as such.
Didn't notice any marks at all? This is the H1 clutch and the spring plate is very basic not like on the H2. I may be wrong but I don't think it really matters where the plate goes on the H1.
I have now rebuilt the clutch with new actuator et al and even tough its all new except for the spring plate the bloody thing still drags
!! I have used ATF in the g/box to see if that may change things but to no avail. I'm now left with either its a problem with the spring plate that has indeed visible 'irregularities' or not enough throw on the actuator.
Luckily I have a NOS spring plate and another OEM actuator on the way.
I was wondering if any other board members have any experience with the German made actuators? Also is it possible to use the H2 spring plate on the H1 clutch as its far sturdier in design.
