jbabl wrote:
Let's see if I get used to it, certainly feels very different. But it also seems like the new one doesn't travel as far(?) Maybe because I have the 15 plate system, but then again the stock actuator adjusted was doing the job. So maybe I need a little more travel on my clutch lever. Maybe I can shave off let's say 1/8 inch where it meets the base so there's a bit more travel when I pull it-
Still thinking the stock one acts faster, engages towards the end. With the new one, I can feel the plates start to meet way earlier, less than half way through then fully engage way at the end
I'll play with it for the next few hours, maybe what I need is a bit more travel
Thanks again for the input
It was just explained.........
Old is fast (coarse) new is slow (fine) Movement is reduced. Get a dog leg lever for more lever travel. Or do the mod. As it is, there is a very fine line between slipping and dragging. You have to make sure the arm is as far down as possible, with 1/8 turn backed off for expansion.
