Mark Hasse came up with a cool "fix" for the sy-techs. they are a finer thread, which reduces the pull. But the lever arm doesn't not move many degrees. He just moved the cable pivot inward by 10mm, and has the best of both worlds. Light pull and enough movement of the arm.....
We had a big discussion years ago regarding the palte mod and Sytec.
I had posted specs between stock and Sytec regarding how much travel the clutch had when measured with a dial indicator and the sytec was consdierably less travel.
Must have had it apart 5 times and the sytec did not have enough travel for a complete release with my old H1D.
Mark's idea is a good one; I used a different lever in the stock perch to obtain the same results.
