It is currently Thu May 16, 2024 7:22 pm
PostPosted: Thu Feb 16, 2012 4:35 am
WTF .
My new rear brake light switch turned up and the spring is way to short. Are they that different for a KH500 compared to a H1 ?
http://i1240.photobucket.com/albums/gg4 ... spring.jpg
Steve
PostPosted: Thu Feb 16, 2012 7:20 am
Does look a bit short, but cant you adjust the clamp nuts to lower the switch down towards the pedal?
Looks to be all the way out now.
PostPosted: Thu Feb 16, 2012 7:24 am
That spring is like what is used on S series. Switches are the same but springs differ.
PostPosted: Thu Feb 16, 2012 10:45 am
Dale you scare me - you really do!
Springs, I just use what ever I have, pack-rat them for years now but local auto supply Help section is good - Ace Hardware has some too.
Modify the Modify!
I've been waiting for my switch to die, it's the original 1972. I have a spare just waiting but I usually go by the saying "if it ain't broken don't fix it"...
PostPosted: Thu Feb 16, 2012 5:30 pm
Ernie, your local bike wrecker will have a zillion springs, they should give you one!
PostPosted: Thu Feb 16, 2012 7:11 pm
Barry, a couple years ago I kept having my H2's main fuse blow at what seemed like random times. While I was trying to figure out what was causing it, I installed a circuit breaker in place of the fuse. I finally found that it was the rear brake switch that was shorting to ground... sometimes. At least I have a nice circuit breaker now, as well as a new switch. :lol:
PostPosted: Thu Feb 16, 2012 7:17 pm
Wow Jim, sounds like a trouble I had on my old F100. Intermittently I would loose my tail lights (fuse pop). I wired in a 12v light off the hot/feed side of the fuse through a toggle switch (so I could turn off the light and not drain the battery when it's going to sit for a while). Been a few years and I've only blown the fuse once that I remember (light is off when fuse blows).
I think what it's doing is acting like a ballast (we called them that in the Phone Company). Dunno - you know more about these things than me. But you can see the red light and toggle switch in the picture in the middle of the dash above the gauges.
PostPosted: Fri Feb 17, 2012 7:28 am
cool Roo shooting machine. Reminds me of the 70's with the 22's out the winda. Had to be in Oz to expereince that one. At least the H1's are world wide.
Steve
