It is currently Fri May 03, 2024 8:22 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Feb 17, 2012 1:50 pm
After installing many many chains and master links, the biggest problem with a normal master link is springing or bending the clip. Therefore I never use anything but my bare fingers to install a master link clip. I usually can't screw it up that way.
PostPosted: Fri Feb 17, 2012 2:02 pm
You got some strong fingers there Joe........ :o
PostPosted: Fri Feb 17, 2012 2:10 pm
Uhh... yeah! Can you start a H2 by hand? :lol:
PostPosted: Fri Feb 17, 2012 3:43 pm
Too funny! I have a nice cheap pair of regular pliers with a nice square front edge works just fine for me.
PostPosted: Fri Feb 17, 2012 5:06 pm
[quote="You got some strong fingers there Joe........ :o[/quote]
It is not about strength, Grasshopper, it is about technique....
Determine the leading end of the master link, grasp the clip in your right index finger and thumb, slide the clip over the leading pin all the way seating the closed end of the clip (with the clip 90 degrees to the chain) swing the open end of the clip up past its final position allowing the one leg of the clip to drop into place behind the protruding part of the trailing pin, swing the free leg in and downward, it will slip into place and viola' you are done!
You always have to spring the clip a little to get it into place, so this method does not permanently bend the clip any more than any other method.
Fingers..... Grasshopper....
PostPosted: Fri Feb 17, 2012 7:03 pm
I used to know this girl who told me pretty much the same thing.........................!
