ZERO wrote:
50 TO 1 IS 2.6 OZ According to Klotz. Im thinking about 3 oz per gallon for now. At least Ill be able to ride untill (if) the issue gets resolved. Im capping it off in the morning!
1 gallon = 128 ounces, so if you want a 40:1 mix, for example, divide 128 by 40 = 3.2 ounces per gallon.
Mixing 3 ounces per gallon, you'll get 128 / 3 = 42.66, or about 43:1
3 guys were traveling together, they got tired and decided to spend the night at a motel. There was only one room left, so they took it. It was 30.00 so they each gave the owner 10 dollars. A bit later the owner felt bad and decided to reduce the rate 5 dollars, so he gave his son 5 dollars to return the the guys. On the way the son decided the guys wouldn't know the difference, so he got to their room and told them they each get a dollar back.
So they each paid 9 dollars (27 dollars) and the son kept 2 dollars 27+2=29 dollars......... Where did the other dollar go?
What does this have to do with oil ratios? absolutely nothing. I just wanted this thread to go off on a tangent!.......
