It is currently Thu Oct 31, 2024 7:37 pm
PostPosted: Wed Jan 25, 2012 10:51 am
I used to be anal-stupid about using a new clutch cover gasket when I pulled the cover off. I went through a period when I did this a lot and remembered a post from Moo I think - where he reused it many times with no problems.
With nothing to loose I started doing this. I did use Yamabond on the cover side and nothing where it meets the case. I was worried about the two shaft seals - Kicker and right-side shifter on my H2 but they've never leaked either.
So far I've gone through 6 cycles of NOT changing out the gasket when I pull the cover off as it comes clean and the gasket is in one piece and not damaged. I remember when I first put it on I used a light coat of silicon spray on the case side but only that one time. No leaks or oozing anywhere since and it's been a long time I've been reusing it.
I'm not saying NOT to use a new gasket, I'm saying MINE has been fine so far. If it leaks - fine I'll replace it but until then I've saved a few bucks and the hassle of keeping them in stock.
Adding this for Search reasons only.
PostPosted: Wed Jan 25, 2012 1:13 pm
I've re-used mine too. Unfortunately most of the time I have taken the cover off to redo something I messed up! On my S3 I have a broken gasket (at the bottom) which has a thin coat of anti-seize on it..no leaks.
PostPosted: Wed Jan 25, 2012 1:35 pm
Scraping gaskets is high on my "things I really Hate to do" list. I just use anti-seize on both sides, as there are locationg dowels on the motor.
PostPosted: Wed Jan 25, 2012 1:49 pm
I use a very thin coat of yamabond or similar on cover side and grease or anti-seize on the cases. I use to do this on valve cover gaskets on cars, back in the day. Can be reused many times.
PostPosted: Wed Jan 25, 2012 3:16 pm
I did the same... although I used case sealer on one side and a lick of oil on the case side when putting it together.
I even swapped out my clutch plates once by leaning the bike over instead of draining the oil.
With the above, 15 minute job, tops.
PostPosted: Wed Jan 25, 2012 5:15 pm
I got that tip from LC..so I tried it on the H2 this summer. Leaned her way over, took off the clutch cover...patting myself on the back. I sure was glad no one was around to see me mopping up the mess from the overflow tube... :oops:
PostPosted: Thu Jan 26, 2012 7:09 pm
I've reused gaskets several times. Usually the holes oval out read bad where they wont center is when I change them. :thumbup:
PostPosted: Thu Jan 26, 2012 7:26 pm
You just have to lean it a bit....... :eh:
