It is currently Mon May 05, 2025 8:29 pm
 Post subject: H2 Tire Pressure
PostPosted: Sun Nov 13, 2011 12:29 pm
Is everyone still pretty much running 26-27 front and 30-31 rear?
 Post subject: Re: H2 Tire Pressure
PostPosted: Sun Nov 13, 2011 12:37 pm
Modern tires usually call for higher pressures, especially the front.
Can't remember exactly but about 31-32 fnt, 34-35 back.
PostPosted: Sun Nov 13, 2011 12:38 pm
BT 45's, street and track, 29F, 30 rear.......
PostPosted: Sun Nov 13, 2011 1:01 pm
My tires are a bit oversize, 130/90 rear, 100/90 front, so I've been running 28 F&R. It seems good, but I've never had an S11 complain anyway, so who knows?
PostPosted: Sun Nov 13, 2011 1:09 pm
You should be fine. The tires just run a bit warmer, which is good as long as you don't do a lot of long high speed runs. And the 130 needs it to flatten out a bit. I know there is a lot of tread roll over.
PostPosted: Sun Nov 13, 2011 1:57 pm
Not that much with the 3" Lester. The tire size was the one recommended by Bridgestone for that rim width.
