It is currently Tue May 14, 2024 12:10 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: 34 mm fuel level
PostPosted: Wed Nov 25, 2020 12:02 pm
yes I did see that thanks, that's why I want to compare the two . cause I have suspicion its rich
PostPosted: Wed Nov 25, 2020 1:02 pm
I have TM34s on my H2B, not the same carb, but find the new Mikunis come with a max height fuel level setting from the factory. Because of this and the forward mount angle on the H2, I had to lower the fuel levels quite a bit.
PostPosted: Wed Nov 25, 2020 3:51 pm
We found that almost every Mikuni carb on brand new bikes being assembled and set up right out of the crate, had excessively high liquid levels, as Mikuni just builds the carbs, they don't "finalize" them for the model in float heights.
There were even a couple of singles, F series and one other, that were so rich, not just from floats too high, but from the wrong slide cut away. F5A was one of them, FDM to cut the slide form a 2.5 to a full 3.5 on the slide cutaway.
Once the cars were right in adjustments to floats and balance, the engines usually became rocket ships.
We even got Tech Services and Service School instructors to get most of the techs to pull the carbs right in setup, set the float levels, so they didn't have issues later. We could tell the good dealerships from the ones that didn't pay attention, the good shops sold bikes that were ballistic missiles, the rest had ongoing "tuning issues" from excessive richness. Oil pump settings and relief valve pressures were another big deal, getting this stuff right made a serious difference in a slug, vs a runner.
PostPosted: Wed Nov 25, 2020 4:07 pm
Thanks guys, yea i started with 2.5 throttle cutaway 40 pilots 220 mains 159 - q2 emulsions 6dh4 2nd from top 3.3 float valves, any thoughts on my jetting please advise! but then i put modified throttle cutaways and bam tons of low end, I got them years ago from GAST the size is ground off , the size must be at least 6.0 . My H2C is stock bored .020 over stock ports stock heads, pump gas , Denco baffled chambers,uniys for filters.any more advise? please welcome!
PostPosted: Wed Nov 25, 2020 5:05 pm
Check the jetting examples page of the resource site.
PostPosted: Wed Nov 25, 2020 5:46 pm
yes I did thanks, anybody use those throttle cutaways I mentioned with success? and mentioned jetting?
PostPosted: Wed Nov 25, 2020 8:22 pm
What I was referring to on the cutaways was for stock carbs on stock engines, NOT 34's.
The best jetting specs for a stock to near stock H2 are the DENCO street 34's settings.
PostPosted: Wed Nov 25, 2020 8:56 pm
yes tuner, i understand what you met thanks, I'm just trying to get approx jetting for vm 34 mm, with dencos with those 34 mm throttle valves that are modified.
PostPosted: Thu Nov 26, 2020 4:48 pm
Hello H2 Tuner,
Where can i find that exact jetting for stock to near stock with dencos and vm 34 mm mikuni ?
PostPosted: Thu Nov 26, 2020 9:14 pm
Ask Tony Nicosia, old time triples racer and Denvo owner. He hangs out on Facebook.
