It is currently Sun Jul 13, 2025 5:47 pm
PostPosted: Sun Jun 21, 2020 11:58 am
My left en right chambers are leaking oil,at the exhaust port, even after replacing the gaskets twice, mount with some blue silicon gasket.
Can I cure this by using two gaskets on top of each other?
Or do I have to put (a lot) more silicon gasket on them...??
1973 Kawasaki 750 H2A,
1969 Garelli Rekord 50cc,
1985 Ducati Mille MHR.
PostPosted: Sun Jun 21, 2020 6:20 pm
Here's one method:
http://kawatriple.com/tips/seal_chambers.htm
OR,
scrambler73 wrote:
Mike posted up this trick a while back.. and its one of my favorites! :thumbup:
Use the blue rubber (made of high temp silicone) gasket that is usually used to seal the headpipe to muffler connection on the stock early H1 and H2 pipes. This gasket hides beneath the chrome connection-clamp and unseen on stock mufflers, but as you can see on the dencos it goes OVER the connection.
I used this trick on both of my bikes with Dencos (one set is from Jim). Its works GREAT as there is a "step" molded into the inner bore of the rubber gasket.
With a bit of high temp RTV in the groove of the manifold AND the rubber gasket OVER the pipe/flange, there is little to no leakage at all.
Straight up RTV will work for a while, but in my experience ALWAYS fails on the denco/wirges type flanges.. Especially with rubber mounted motor and rubbermounted pipes.
PostPosted: Mon Jun 22, 2020 9:45 am
What is "copper RTV"..?
I have ordered black, ultra high temp silicon gasket, I hope this will be OK.
Oil all over the chrome exhaust ( headers) and front of the engine isn't a good sight imo...
PostPosted: Tue Jun 23, 2020 9:08 am
Any silicone works fine, so no worries.
