I would expect Rod mfgs to have this (peen) as part of their process. I would expect OEMs would include this step also but, can't prove it. Aftermarkets may skip this steps why this post for example.
The other concern to me is machining tolerance on rod. For example, once you install the aftermarket rod how much rocking distance did you measure/see? BE Bearing roller tolerance/grading seem to vary quite a bit as well. I have heard guys throw away aftermarket BE bearing and use OEM or Silver cage for better quality machining. Silver cage bearings are prefered over copper if you can locate piece quantities.
I now test the complete assembly in a vice before I have them installed and check for rocking distance. I have purchase aftermarket set's for other bikes before, and too much rocking distance ...even crank re-builder would not install.
This is one of those items where quality is really going to matter, if you want to keep the bike.
So the reason for this post is to understand such questions for those who have used aftermarket rods on H1. And, have I missed a quality aftermarket supplier as I am new to H1s.
ProX claims they do peen a part of the process
http://blog.pro-x.com/prox-connecting-r ... em-quality.
I am used to acquiring may own parts and sending to rebuilder. Regardless if provided I would like to know what I am using. NOS if you can find with no shelf damage/surface rust on machined surfaces or without some one who sanded the shite out of it to remove signs of rust (easy to tell once in you hand ... no. more nice X cross hatch nobe marks). Or they won't show this area in their pics nor will answer questions when you ask.
You just got to love vintage bikes where parts have been obsolete for decades!
