It is currently Sun Apr 28, 2024 1:33 am
PostPosted: Sun Mar 06, 2016 5:56 am
Today I discoverd a crack in the steering damper bracket on my H2A.
So it needs to welded, is it enough to disconect the battery, or do I have to disconect anything else to avoid any damage to ignition, charger etc.?
1973 Kawasaki 750 H2A,
1969 Garelli Rekord 50cc,
1985 Ducati Mille MHR.
PostPosted: Sun Mar 06, 2016 9:18 am
I welded a broken engine mount on my H2 without disconnecting anything. I put the welder's ground clamp securely on the frame near the repair, and there was no problem. As they say, your mileage may vary.
PostPosted: Sun Mar 06, 2016 10:30 am
OK thanks.
"Your milage may vary" you mean how long the weld will last...??
PostPosted: Sun Mar 06, 2016 11:41 am
No, I meant "Proceed at your own risk." There are no sensitive computers on a triple, and the electronics are all robust old fashioned devices, so it would be hard to cause damage. Attaching the ground clamp near the weld should be enough to provide safety, but if you're welding the damper bracket and a slip of your hand causes the arc to wander to a nearby wire, there will be trouble. In other words, use common sense.
PostPosted: Sun Mar 06, 2016 12:34 pm
I will, :thumbup:
PostPosted: Tue Mar 06, 2018 11:20 am
It's finaly done..!!
PostPosted: Tue Mar 06, 2018 7:40 pm
Welded many times - clamp near weld for poops and grins.... nary a problem.
