Any thoughts on how to fix this issue? http://www.kawi2strokes.com/forum/viewtopic.php?f=14&t=13142 |
Page 1 of 2 |
Author: | Hillclimber [ Fri Nov 03, 2017 4:57 pm ] |
Post subject: | Any thoughts on how to fix this issue? |
Author: | Ja-Moo [ Fri Nov 03, 2017 5:33 pm ] |
Post subject: | Re: Any thoughts on how to fix this issue? |
you need to add more explanation, please. |
Author: | Hillclimber [ Fri Nov 03, 2017 6:54 pm ] |
The locating pin was pushed up right through the top of the engine case. Is there some way of fixing this or is the engine case now garbage? |
Author: | Hillclimber [ Fri Nov 03, 2017 6:56 pm ] |
This is the locating pin in the transmission holding the top shaft in place. |
Author: | Evans Ward [ Fri Nov 03, 2017 7:03 pm ] |
You can take a small drift punch and tap it carefully back in place from the other outer case side. I did this on mine years ago and it has held up well. A little JB Weld in the outer case hole side and Robert is your uncle. |
Author: | Ja-Moo [ Fri Nov 03, 2017 7:31 pm ] |
Evan's got it! Not a biggie! |
Author: | Hillclimber [ Sat Nov 04, 2017 4:46 am ] |
I had considered this but did not know if it would hold. I thought/hoped someone here would have dealt with this before. I will go ahead and do it with JB Weld. Thank you to all |
Author: | Tim Steele [ Sat Nov 04, 2017 7:17 am ] |
Just now seeing this. I have done the same repair and it worked perfect. |
Author: | Ja-Moo [ Sat Nov 04, 2017 10:03 am ] |
I have done it too. No biggie. |
Author: | H1FR [ Wed Nov 08, 2017 11:57 am ] |
3 of the 4 are easy, just one can ruin your day. |
