Removing gas tank sealer http://www.kawi2strokes.com/forum/viewtopic.php?f=14&t=12768 |
Page 1 of 2 |
Author: | GUTS [ Mon May 08, 2017 9:53 am ] |
Post subject: | Removing gas tank sealer |
I have a tank from a TC Turbo that I was going to de-rust for my pal Leroy. It has been coated with some kind of tank sealer. It is degrading badly. What do I use to loosen it up or dissolve it away? |
Author: | Stev-o [ Mon May 08, 2017 10:01 am ] |
Post subject: | Re: Removing gas tank sealer |
Hey Jeff......M.E.K should handle it, it may be available at your local WalMart https://www.mscdirect.com/browse/tnpla/ ... AiHW8P8HAQ |
Author: | GUTS [ Tue May 09, 2017 8:25 am ] |
Thanks for the tip Brother, I will give it a try. |
Author: | Ja-Moo [ Tue May 09, 2017 8:52 am ] |
Freakin nasty stuff. Be VERY careful............ |
Author: | Stev-o [ Tue May 09, 2017 10:11 am ] |
Ja-Moo wrote: Freakin nasty stuff. Be VERY careful............ It is, but thats what allows it to work so well. |
Author: | Ja-Moo [ Tue May 09, 2017 11:15 am ] |
Acetone also works, just slower. |
Author: | Jim C [ Tue May 09, 2017 12:50 pm ] |
I've been down this road before. The soft stuff like Creme is horrible as it can come out in small soft pieces. I've tried MEK, lacquer thinner, Acetone, etc. It often comes down to using something sharp and abrasive like drywall screws and a piece of chain (the kind with the bent pieces that are sharp). Tons of shaking and flushing. As far as resealing: I had a tank that had a lot of rust. Used Evaporust and the above items to get all the loose material off. I then coated with Caswell. I think the stuff works OK and is clear although it was barely enough for a 5 gallon tank. It looks like epoxy and dries clear and hard. The remnants of the mixed material is now covering a small hole in the concrete garage floor and is incredibly tough. A restoration guy recommended Bill Hirsch tank sealer. Not sure who it's made by but apparently car restorers prefer it. I asked them if I could put it over top of the Caswell material and they said it was originally intended to be used against rusty steel and could not recommend it over any other type of sealer. |
Author: | Jim [ Tue May 09, 2017 1:19 pm ] |
The Caswell stuff is Phenolic Epoxy, which is resistant to everything in today's gasoline, and is used to line big commercial fuel storage tanks. I believe you can buy the stuff generically cheaper than Caswell sells it. Someone here has done that. |
Author: | soflah2b [ Tue May 09, 2017 3:40 pm ] |
I've done the MEK, drywall screws in the tank in the dryer, then removed remaining rust with electrolysis. Worked well, just took some time. |
Author: | GUTS [ Tue May 09, 2017 5:00 pm ] |
Thanks guys. I'm not having problems with rust, I de-rust lot's of tanks and I have not found anything better than Evaporust. I just need to remove the remaining sealer. I'm thinking hardware and rotation will be the answer. |
