It is currently Wed Jul 09, 2025 2:41 am
 Post subject: H2B ground leads
PostPosted: Fri Apr 21, 2017 12:34 am
There are three ground wires listed in the H2B parts book. The larger gauge one is 270mm long and is the battery lead. Pretty obvious where one end goes, but what position does the other end get bolted to for the actual ground? The other two are 200mm and 120mm long, what do these get attached to? Thank you.
 Post subject: Re: H2B ground leads
PostPosted: Fri Apr 21, 2017 1:02 am
Lotsa good info on a restoration thread.
Click tab up top for WIRING
Good Luck, the pics are nice.
http://translate.google.com/translate?h ... 2.free.fr/
PostPosted: Fri Apr 21, 2017 10:06 pm
Thanks, yes, good pics, but most are of H2, not B model. I guess I need to see more wiring route detail etc for the H2B as well.
PostPosted: Sat Apr 22, 2017 1:09 am
Here's is a couple of pictures from a H2C.
The wiring diagram is from a H2B.
I believe the H2B and H2C share the same electrical system grounds.
Hope this helps.
72 H2, 75 H2C
PostPosted: Sat Apr 22, 2017 1:11 am
There are 4 total grounds.
Check out the wiring diagram for there locations.
Note: The battery ground wire is missing in these two photos.
72 H2, 75 H2C
PostPosted: Sat Apr 22, 2017 11:03 am
Thank you very much! OK, I wondered what those three threaded holes were for on that frame beam. So the CDI boxes get grounded directly as well. Will have to be sure to scrape the paint off for a good ground connection on the frame then.
