It is currently Tue Jul 08, 2025 3:58 am
 Post subject: Looking for quick fix
PostPosted: Sun Apr 16, 2017 9:16 am
1975 S3 starts hard and will not idle at all, runs great and pulls hard all the way to 9000 RPMs. Up north here the bike sits a lot because of cool weather. Bike was ran in early Feb (and yes I froze) but ran great and idled well. So the bike has sat since. I have had similar issues in past after sitting, low idle but most times riding the bike it straightens it's self out. I do try and run the fuel out before shut down. The carbs were completely redone about 1500 miles ago. Is there a product anyone has used to run to help with issue. Just hoping for an "fix" before removing all the carbs.
Thanks
PostPosted: Sun Apr 16, 2017 9:28 am
I like Seafoam but the proper way is to pull the carbs and clean them. Actually as easy as pulling the carbs is, it IS actually a quick fix. Also a fresh set of plugs won't hurt.
https://seafoamsales.com/sea-foam-offic ... -sea-foam/
PostPosted: Sun Apr 16, 2017 10:14 am
Most likely your pilot jets need cleaning. They will clog after sitting for an extended period.
PostPosted: Sun Apr 16, 2017 2:28 pm
Drain the fuel bowls and take it out and rev it if that doesn't work work on it as it is a two stroke. Just a thought
PostPosted: Wed Apr 19, 2017 5:13 am
Pilot jets and choke circuits clogged. Stinking alcohol.....
Lane
